Salta al contenuto principale
Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
31 Domande Visualizza tutte
Flew my drone in my pool will it ever work again thank you for your co
Flew my drone in the pool will it ever fly again thank you for your
Questa è una buona domanda?
Punteggio 0
1 Commento
Have you removed the batteries? Opened it up to clean out any water that got inside? The longer the water sits in it, the greater the chance of corrosion.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
It will basically depend on if you tryed to fly it immediately after it being in the water and how much water for into the actual motors and in the electronics. If you allowed it to dry good before turning it back on the. You might get lucky because I would assume that drones do have some sort of water resistance!
Punteggio 1
Aggiungi la tua risposta
Michael Souder sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 42
