Salta al contenuto principale
Repair guides and troubleshooting for the Whirlpool Quiet Partner II insulated dishwasher.
53 Domande Visualizza tutte
My Quiet Partner II has no lights
My Quiet Partner II M# DU1148XTPB1 has no lights and I've reset the breaker for the entire house just to be sure
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi,
Check if the door switch (supplier example only) is electrically OK. Here's how to do this.
Be safety aware and ensure that the power is completely disconnected from the dishwasher before testing the switch.
If the switch is OK then check if the dishwasher fuse (supplier example only) is OK.
Be aware that if the fuse is blown then there's always a reason for this and it will have to be found as you may find that if you replace the fuse that it will blow again once the dishwasher has started.
If either part is faulty search online using the manufacturer's part number only (found in links) to get results for suppliers that suit you best.
Immagine WP8269209 - Whirlpool Dishwasher Switch
Prodotto
$23.99
Immagine 8193762 - Whirlpool Dishwasher Thermal Fuse
Prodotto
$37.99
Punteggio 1
Aggiungi la tua risposta
Seymone Trueshell sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 24
Tutti i Tempi: 408
