If I connect two iPhone batteries to one bms in parallel would it work
If I connected two of the same iPhone se 2020 batteries to one iPhone BMS with them both being at the same voltage and both being at the same battery health and same percentage would this work?
My Goal is to be able to double the battery capacity of the iPhone, I am currently just wanting to test this on iPhone SE but then using a custom housing I am likely going to attempt this on an iPhone 13 Pro Max if it works on the iPhone SE2.
I want the phone to recognise it as one battery while there is two batteries installed and I'm assuming based off of my current research connecting two iPhone batteries to one BMS would be the way to go about doing this.
Thank you in advanced for your responses :)
Questa è una buona domanda?
