I cant remove my playstion from safe mode and only shows red light?
Remove From Safe mode
Questa è una buona domanda?
Hi @bigbio
I can't gauge what you mean based off the information available so it might be a good idea to go to: Adding images to an existing question. However i can give you some vague advice:
Firstly, can you research and see what you find. I couldn't find anything
Then, maybe try the hard drive swap and see if that works (That's unlikely)
Do you get a display out?
Also, do you happen to be able to plug in a controller and interact with it.
If you try any option in the OSD, does it flash up an error?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 15
