Salta al contenuto principale
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 Domande Visualizza tutte
The screen "unglued" and broke, repaired now it's painfully slow
Hey, I have the very same trouble. Change of hdd to SSD and was working like a charm for 7 months, then the screen "unglued" and broke. I took it to a repair shop and since it's painfully slow. I have to add that when I changed the ssd I used a sensor temperature cable so I didn't had to use any kind of fan controlling app. Since the screen replacement, the shop had to install one to make the fan go quiet. Any ideas of what is going wrong please ?
Here is a screenshot of TG PRO app.
BIG THANKS IN ADVANCE ==
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I'm thinking they forgot to move the display thermal sensor over from the old display as some display sellers don't supply it with the new screen or was defective. Or one of the power sensors is having an issue.
I would run the onboard diagnostics to see what it tells you. Restart your system and press the D key to enter
Reference: Mac startup key combinations
Let us know what the error code is.
Punteggio 0
Aggiungi la tua risposta
rom tirom sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 31
