My screen fades/distorts, but an external monitor works fine.
About a month ago my A1226 MBPro started acting up. The display would show symptoms similar to those seen in this video:
http://www.youtube.com/watch?v=yCceE5Ocf...
At first, varying degrees of physical manipulation of the display would fix the problem. Often just closing the screen and reopening it would remedy the problem, or wiggling the screen back and forth.
As time progressed, the issue became worse, and eventually no amount of manipulation could get the display to function correctly.
What I've done / relevant information:
1. This MBPro does have the 8600 GPU that has issues, however my logic board was replaced under warranty after this issue developed AND my laptop works perfect with an external monitor.
2. I replaced the LVDS (display cable) as most of my research pointed to it as the culprit.
Anyone have any suggestions on what I can do aside from replacing the entire display?
The only other part I can think of that I could replace is the 'led inverter board', however the backlight functions fine, so I'm not sure that will do anything.
I'm finding it harder and harder to sink big money into this barely 5 year old, $2500 laptop, that in perfect condition, can be had on eBay for about $650.
Questa è una buona domanda?
1 Commento
Hi Ken,
Have you seen this video?
http://www.youtube.com/watch?v=fvxq6kPcV...
It follows the same principle that you're describing, that the laptop must heat up before the screen works properly. I'm not sure if this is a logic board, or display issue, but regardless it's extremely frustrating and problems like this shouldn't develop four years after purchasing such an expensive machine.
da Jeff
