Salta al contenuto principale
Repair guides and service manuals for the Respironics REMstar Choice Nasal CPAP device.
2 Domande Visualizza tutte
Can pressure setting be changed on Remstar Choice LS
I have this older machine. I need to have the Pressure increased. Is this something I can do? Or does it need to be taken somewhere??
Thanks,
John Daniels
Questa è una buona domanda?
Punteggio 1
1 Commento
You need a new sleep study to determine what pressure level you need and they can adjust the level on the sim chip.
Sorry, I haven't checked mine out to see is you can do it yourself. But a new study will take care of the problem and tell you if you have a bigger problem than before.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Jj Daniels you really should get those pressure properly adjust by someone in the BioMed field or rep for this device. Speak with your healthcare provider about that.
For educational purpose, there should be a small door on the bottom right. If you remove that, there should be a slot that says "Pressure" You would need a screwdriver to adjust it. There are no preset pressures and you would need a manometer to get the proper pressures. Again, have your healthcare provider assist you with that.
Punteggio 1
1 Commento:
Thank you! I will take it to my provider. I would not trust myself to mess around with that stuff!
da
Aggiungi la tua risposta
Jj Daniels sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 150
