Salta al contenuto principale
The Asus ROG Strix GL702VM-BHI7N09 is a gaming computer released by Asus in January 2017. It can be identified by the serial number on the bottom of the keyboard.
22 Domande Visualizza tutte
Asus FX-505DT Doesn’t start
Hello, I have a ASUS FC505DT Gaming laptop for 3 years now, and it always had some problems with blue screens and stuff and forums said it was about my ram, so recently my screen was cracked as well. So this was the perfect time for me to replace my screen and upgrade my ram from 8GB to 16GB. After I have had the screen replaced and ram upgraded, the person that did it said it won’t turn on anymore, so I took it back home to have a look for myself. And the keyboard only lights up when I have the Power Adapter connected to the laptop. I don’t hear any of the vans spinning or my laptop booting. Nothing helps, I also have done a full reset with removing the battery and waiting, but that didn’t work either.
Please tel me this is fixable!
Specs: Asus fx505dt
Ryzen7 AMD
NVIDEA GEFORCE GTX
Realtek model: RTL8821CE
SN: K4NRCV019932156
CN: K3ZA
MFD: 2019-04
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
check the ram, could be a bad module causing this issue
Punteggio 1
8 Commenti:
I switched the ram cards with each spot, and put my original ram back in its original place but It doesn’t seem to fix the problem, or do you mean something else?
da
no thats what i meant, try ram in the top slot only incase theres a connection issue with the board
da
that sadly didn’t work either
da
@andykhoven have you tried disconnecting the screen
da
I self didn’t, how would disconnecting the screen make my laptop turn on?
da
Mostra altri 3 commenti
Take it back to the person that "repaired" it. They obviously stuffed it up.
Punteggio 1
Aggiungi la tua risposta
Andy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 77
