Salta al contenuto principale
The second generation PlayStation Vita, the PCH-2000 series, is commonly referred to as either the PS Vita Slim or the PS Vita 2000. Announced in Japan fall 2013, and released in North America in May 2014. It is rated as a hand held entertainment device. Supported by :: Wi‑Fi, PlayStation Now, PlayStation Network / Plus, Bluetooth. Model number: PCH-2001.
72 Domande Visualizza tutte
green light when power button pressed, but only get a black screen
So I've been having this problem for about 4-5 months now and i'm not sure what to do anymore, I've unplugged everything and made sure that every single wire is back in it's place, and when I go to boot it into safe mode I only get a black screen
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi Gavin! To be honest, this is most likely a motherboard issue. Some PSP's are showing the same issue. I only had this once, as I disassembled the PSP, a IC came clean off the motherboard (can't remember which IC came off). I recommend to open it up and check what's wrong and reball (solder) it. Or replace the motherboard (this is more expensive).
Punteggio 0
Aggiungi la tua risposta
Gavin K sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 35
Tutti i Tempi: 636
