Salta al contenuto principale
The third redesigned generation Grand Vitara was introduced in 2005. The Grand Vitara is called Escudo in some markets. Also, in some markets the three-door variant drops the "Grand" to be branded simply "Vitara". In some countries, including Chile the 5-door version is named Grand Nomade.
rear turn signal bulb left side
can not get the lense cover off rear tail lite of 2007 grande vitara suzuki
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi,
You don’t take the lens cover off, you remove the entire tail light assembly and remove the bulb from the rear of the assembly.
Here’s a video that may help. It shows how to remove the right side tail light assembly but it is the same for the left side, in that you need to unbolt the assembly to remove it from the body of the vehicle.
Punteggio 2
Aggiungi la tua risposta
brenda Hassler sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 610
