MacBook optical drive in iBook
Can I replace iBook G4's optical drive with one from MacBook (A1181)?
Questa è una buona domanda?
MacBook drives use the same PATA interface until the Early/Mid 2009 models.
Regardless, iBooks use a full-sized drive, and the MacBooks use slimline drives, so they are not compatible. Sorry!
They're definitely not inter- changeable. The iBook uses Pata connector and the A1181 uses a sata interface.
Are you thinking of hard drives? The A1181 uses the same interface until Early 2009 models.
You're right Ben, good eye!!! I was thinking hard drives. Thanks for the pull_up!!
As you can see here, I don't believe that the drives are interchangeable.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,108
1 Commento
If one of these answers fixed your problem please hit the "accept" in list that has "History Edit Flag Accept Comment" located to the upper right of your question so we can remove it form the unanswered list.
da mayer
