Keyboard Backlight Problems MBP17 Unibody
Hi I have two Unibody MBP17 a matte and a glossy screen, I changed out the two displays and has a keyboard light does not work both PLEASE HELP!!!!
Questa è una buona domanda?
Hi,
Have same issues with my A1297 MacBook Early 2009 MacBook Pro 2,66 GHz
After changing the uppercase my backlight does not work properly!
I noticed, that covering the sensor near the camera turns the keyboard backlight on,
BUT I CAN'T CHANGE THE BRIGHTNESS (NO F5 AND F6 BUTTON WORKING!)
Cable was checked and is connected.
Does anybody have any suggestion, where the problem could be? When i push the button, it's greyed with a prohibitory sign...
Any idea? Thanks in advance!
== Update ==
Problem solved: Covering the light sensor next to the camera --> f5 f6 work (dark)
if it's bright outside --> f5 f6 are disabled
Thank You anyways
Try resetting the SMC.
What kind of picture? Both of them is the same type MBP17 unibody 2.66 ghz/ both of them are working perfect after I changed the displays the keyboard back light is not working
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,375
