Salta al contenuto principale
The Xtreme 3 from JBL is a Bluetooth-powered speaker, and is the 3rd generation of the Xtreme series of speakers.
7 Domande Visualizza tutte
My xtreme 3 won't charge
I brought a jbl xtreme 3 2 weeks ago the battery has died and I can't get it to charge. I plug it in and it just turns back off
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Hello Katie, plug it into the computer , as if the computer would be charging it , open your options for external discs, find the device , go into the settings if possible, or if not possible , eject the device with options from the computer. then it should work, unless the battery is dislodged, then it’s a lot more complicated.
Punteggio 0
My boombox is completely dead and I can't get it to charge. I thought they when it was dead just plug it in
Punteggio 0
I found the issue on my end. Check the charging board to see if the ribbon cable is connected or if it has a break. If the ribbon cable is not connected, the box won't have charging logic and won't be able to check the battery status. If that doesn't solve the problem, the battery is probably defective.
Punteggio 0
Aggiungi la tua risposta
Katie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 48
Tutti i Tempi: 1,411
