Can I change the failing temperature sensor on the logic board?
I seem to have a failed temperature sensor on the logic board according to the tech shop I sent it to. They had a fail message on a logic board temp. sensor.
1.The computer works when the battery is out and I don't push too many applications.
2.If I put the battery in it gets hot and shuts down. (I have tried a few new batteries.)
Can I change out he sensor myself? How can I find out exactly which one is failed?
Thanks in advance,
Randy
Questa è una buona domanda?
2 Commenti
OK, finally found the install disks and ran the AHT. no faults or error codes found. The computer runs without incident on the power cord and the battery removed.
da Randy Houseman
OK, thanks for the advice. I'll track down the items you mentioned and inspect.
I'll update when that's done.
da Randy Houseman
