Salta al contenuto principale
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
376 Domande Visualizza tutte
27'' iMac 2010 Backlight Failure
The backlight on my 27’’ iMac 2010 is slowly dying. Getting a little more dim every week, and I can see dark spots between the backlight “bulbs(?). I don’t have the tools or the skills to do the soldiering like some people recommend. Should I try to replace the display or does the inverter board solve this issue? How can I tell if it’s the inverter board or the literal backlight strip?
Also does a 2011 display work in a 2010 machine?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Most likely the LED bar connection or a few LED have died and often the backside also gets darkened
Here’s one source iMac 27" A1312 - Mid 2010, Apple P/N 661-5568 and the guide Sostituzione Display nell'iMac Intel EMC 2390 da 27"
Punteggio 1
2 Commenti:
Thanks so much, Dan. Wish the news was better, but I appreciate your expertise. Would a 2011 display work in a 2010? I ask because I found a cheap one in my area.
da
@daevrojn - There are some differences. It will take some work to convert it.
da
Aggiungi la tua risposta
Alex Nevin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 379
