Salta al contenuto principale
The Ram line was redesigned for the 1994 model year. Development on a second generation began in 1986, ending in late 1992.
33 Domande Visualizza tutte
What can I do for my high mileage truck to keep it going
What can I do routine maintenance for my truck it's got a lot of miles on it
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Shawn Jones main thing is that you continue your routine maintenance. Regular oil changes with High-Mileage motor oil is pretty important. Change your spark plugs, belts, filters etc. at regular service intervals. Pay attention to the cooling system (hoses, radiator etc) There is nothing really special about it other than do not let little things build up. As soon as something needs to be looked at, do so to find out the cause of it. It’s an engine that has lots of miles on it so it needs special care quick and not when it breaks down. That is really all you need to do. I am the owner of a PU with 254K and it’s still my daily driver :-)
Punteggio 1
My 96 1500 has 285000 and I change my oil every 7000 miles and transmission fluid and filter every 30000 miles and flush my coolent system twice a year and diff fluid every 20000 miles. And all other parts when needed. If I could afford the gas I wouldn't hesitate to drive across the country. And yes it is my daily drive 40 miles everyday.
Punteggio 1
1 Commento:
Don't forget about the differential fluid
da
Aggiungi la tua risposta
Shawn Jones sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 389
