Salta al contenuto principale
Lanciato il 4 novembre 2017. Modello A1865, A1901. Disponibile con GSM o CDMA / 64 o 256 GB / Colore Silver o Space Grey. Si pronuncia "iPhone 10".
1202 Domande Visualizza tutte
new screen won't attach-- metal tabs broken off?
My son removed the screen on iPhone X (to replace battery) and broke the screen. So ordered a new screen, hooked it up, but when I go to reassemble, it doesn’t want to click-in to the phone body. I’m noticing the removed/broken screen has no metal tabs on the edges, but the new screen has several. Could these metal tabs be broken off in the phone body?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
More than likely when the screen was removed, the actual display came free from the frame it’s mounted to. Included images for reference of what the inside with no display should look like. The silver bit around the edge of the back of the display is likely still seated in the enclosure. You should be able to pop it out with a tool, just be mindful of the battery and other components. The clips just snap in place and will come free with enough force.
Punteggio 3
4 Commenti:
This was exactly it. I was able to remove the bracket and attach the new screen. Thank you very much!
da
Thank you for this post!!!!
da
Yep, me too! Perfect!
da
@kcirsnurb Glad people are still running into this and finding it helpful :)
da
Aggiungi la tua risposta
sethcrothers sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 64
Tutti i Tempi: 872
