Hi @sonnyjunebug,
Here’s the tech sheet for the dishwasher.
Try running the diagnostic tests as described in the tech sheet and check for any error codes etc.
If no codes then run the DW as per normal and when it doesn’t drain, disconnect the power and disconnect the harness from the drain motor and measure the drain pump motor resistance to check if it is within specs i.e. 15Ω-60Ω across pin1 and pin 3 of motor in case it is breaking down due to the current flowing through it.
If the drain pump is faulty search online for WPW10348269 to find suppliers that suit you.
Votato
Annulla
Punteggio
2 Commenti
@sonnyjunebug
What is the make and model number of the DW?
da jayeff
Maytag Model
mdb4949sdh3
da Tina
