My unit is making a loud noise when I breathe in and out
How can I fix the loud noise when breathe in and out?
Questa è una buona domanda?
@rdb88385 sounds like a pressure related issue. Double check your device to see if it is related to the recent CPAP recall. If so you want to contact the company and get directions from that. If it is not, then I would still suggest that you contact ResMed (or your local DME company as well as your health care provider) and see if they can guide you. You are obviously using/needing it and we all want you to stay well
Tighten the strap system as it shouldn't make noise and if it starts whistling put a small bottle of water on the door to the water tank. To stop the face farts tie a handkerchief over the gasket so it covers it and the gasket will last YEARS.
Face farts - best thing I have read in a long time lol
may be water condensed in your air tubing. Sounds loud. drain water if present.
I also experienced this. A sound from within the machine, a sort of wheezing sound that was apparent as I breathed in and out. It was a disturbing sound not having to do with an air leak from the hose, mask, or water tank, as I checked these possibilities first. I discovered the sound was coming from the motor itself. In my case, the motor in my machine was just five years old. I was able to replace the motor quite easily with the aid of a couple of YouTube instructional videos which were easy to find. I was able to purchase a replacement motor which I found on that large online shopping site. I believe it cost $129.00, and it arrived the very next day after I ordered it. I believe that just about anyone can replace their motor with the aid of an instructional video for which there are several on YouTube.
Ultime 24 Ore: 18
Ultimi 7 Giorni: 85
Ultimi 30 Giorni: 421
Tutti i Tempi: 6,769
