Why isn't my battery charging? M1 chip
Hi guys,
I recently bought a MacBook Pro 2020 m1 for a bargain price as it had a coffee spill on the keyboard. When I acquired it, it worked fine as did all the keys etc but they were crunchy when pressed and the backlight had faded in the middle, so I decided to change the keyboard (more info on that at the bottom).
When I put the MacBook back together, it turned on and the keyboard now works fine, but the battery won't charge. I have reseated the battery connection to the Logic Board many times and I have checked the connection of the Thunderbolt ports to the Logic Board, all seems well, it just will not charge. At one point I had an 'X' through the battery, but now I can get Coconut battery to read the battery data, it just won't charge.
I am using the charger that came with it, I have also tried a MacBook 12” Retina charger and swapped the cables, so it's not that. I am aware the 12” Retina charger couldn't even power a potato, but I tried anyway.
Any ideas? I'm stumped.
By the way - there isn't much information regarding the keyboard change on these, so I will say that the keyboard is rivoted on, as well as screwed on. So unless you have a microscopic rivot gun or you're very steady with some metal adhesive, don't bother. I applied tiny amounts of thick adhesive to the top of the rivots and was very careful not to let it run, worked a treat, but I only took that risk as the MacBook owes me very little money.
Thanks!
Andy.
Questa è una buona domanda?
3 Commenti
By the way - there are absolutely no traces of liquid on the Logic Board and before the keyboard change, the battery worked fine.
da Andy
Was there any liquid on the actual logic board when you tore it down to replace the keyboard?
da Alisha C
No, it was fine. Also, the battery worked fine before taking it apart and (apparently) did so for a couple of months prior to me buying it.
da Andy
