Salta al contenuto principale
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
101 Domande Visualizza tutte
Why won’t my system read cartridges
Every time I try and play a cartridge game, it never works I also hear this grinding sound, I have no idea why this is happening, can someone please help
Questa è una buona domanda?
Punteggio 1
2 Commenti
it makes the grinding when on and sitting on a flat surface?
there are no real moving parts in the console so it seems like the grinding would be coming from the speakers probably.
da
No, it’s when I put a cartridge in on any surface
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
You can try replacing the cartridge slot. The grinding might be coming from thing on the pins or in the slot itself.
Punteggio 1
Before replacing the slot, you could try a trick to clean the card reader pins first.
  • get some isopropyl alcohol and thoroughly soak the contact points of any cartridge with a Q-tip.
  • put the cartridge in the slot and insert/eject the cartridge repeatedly for about 3 minutes.
  • try it again and see if that fixed it.
hope this helps!
Punteggio 1
Aggiungi la tua risposta
John Bitzas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 100
