Can display glass be replaced or wholle display must be replaced
On my I mac 27” 2013 display glass is cracked.
Can I replace the glass only, or I have to replace the whole display unit.
Questa è una buona domanda?
Sorry for the loss. Sadly the display and the cover glass are a sealed unit. While someone could carefully peel the two apart it is not something I recommend. Even if you achieve that what will you use to replace the broken cover glass? You would need to find a dead display which to also carefully peel the cover glass off and then re-sandwich the two good parts together if you don’t damage things in the process.
To big a gamble in my mind, besides the time needed would be many more hours than just replacing the display assembly.
Here’s one source of a cheap recycled unit 27” iMac Display Assembly (12/13) - Grade-C
Here’s the guide to put it in: Sostituzione schermo iMac Intel 27" EMC 2639 and you’ll need iMac Intel 27" (2012-2019) Adhesive Strips as well.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 22
