Salta al contenuto principale
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
565 Domande Visualizza tutte
ISight Camera cable has a few wires that are broken off connector
iSight Camera cable has a few wires that are broken/ stretched off the male connector that plugs onto the logic board.
I can remove the male connector out of the female socket but most likely I will rip the wires. I was thinking off the following
  1. is there a connector that I can snap onto the existing cable and plug it in?
  2. Can I micro solder another connector back to the wires. Seems difficult but I don’t mind trying.
  3. Can I buy another iSight cable with connector , snip it, snip the cable that I have currently, join the two wires using another connector/crimper or soldering the wires together.
  4. I know I could use a usb plug in but I want to try and repair because I want to.
I don’t want to take the lcd apart to install the whole cable. The camera worked fine until I put on new thermal paste and during that process the cable got ripped.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I think you’ll end up with a bigger mess than fixing this correctly!
Replacing the cable is not hard in this series. It’s one of the easier ones to replace!
If you are really fixated on not popping off the cover glass to get to the cable, then just get a replacement cable and cut the end off, splicing the connections more cleanly than at the tight endpoint.
Here’s the needed cable 13” MacBook, Airport/Bluetooth/iSight Cable, Apple P/N 661-4820
If you are up to it flow this guide to get the cable out MacBook Unibody Model A1278 LCD Panel Replacement
Punteggio 0
2 Commenti:
Thanks Dan. Your suggestion would definitely work. I agree my plan could be a big mess. Right now, if I were to work on the LCD, I would be in a high risk -low reward situation. Trying to splice the wire would be a low risk, low reward situation. I would definitely try what you suggested maybe three months down the line.
It just seems stupid that splicing and connecting the same gauge wires or cables is so difficult. There has to be a standard connector/crimper that could perform this function.
I do have a few questions for you-
1. The link for the iSight cable you mention has Bluetooth/airport in it. My Bluetooth is working just fine. Is there just one cable that provides connections for Bluetooth, camera and airport or is it that the same cable is used these functionalities separately or together depending on your Mac series.
2. Would you happen to know the gauge of the wires inside this cable? It may help trying to figure out what supplies I might need for splicing/ soldering or crimping.
da
Did you select the correct system? Double check by plugging in the S/N here EveryMac - Lookup
Some models have WiFi/Bluetooth board located in a different connection and only the antenna wires go to the lid.
da
Aggiungi la tua risposta
Pat Perusal sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 339
