Salta al contenuto principale
A color version of the Nintendo Game Boy, released in 1998. Repair of this device is straightforward.
Gameboy won't turn on
Hi all, doing my best to repair an old GBC and I’m a bit stumped.
The GBC won’t turn on. No power light, nothing on the LCD, nothing from the speaker, etc.
Here is what I have checked:
  • Fresh batteries, verified to be charged with a multimeter
  • Good power switch. It has been cleaned several times, and also verified using continuity mode from pin 3 to pin C when in the on position. Resistance measured was minimal
  • Both fuse F1 and F2 are also good. With the power switch on I’ve tested continuity all the way from pin C on the power switch to the far end of F2 and it was great.
  • Cleaned battery contacts (though they were immaculate to begin with)
  • Inspected board for visible corrosion or water damage, again the board looks to be in great shape
Everything looks great, but still I’m getting nothing. I’m new to repair so at this point I’m kinda at a loss for where to go next. Any recommendations?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
try disconnecting the screen and listen for the boot. sometimes the digitizer ribbon can go bad. jsut a shot in the dark though.
Punteggio 0
Aggiungi la tua risposta
Thomas Fansler sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 601
