Fans stuck at full speed
Replaced the logic board and ssd in my MacBook and now the fan is stuck at max speed. I have tried to control the fan with Macs Fan Control but it doesn’t work and TG Pro is reporting normal temps but TG pro sometimes reports that the fan isn’t on because temps are so low.
I have tried reseting PRAM and SMC with no luck
Questa è una buona domanda?
2 Commenti
If you can run the onboard diagnostics, press the D key when you restart or better yet get the full version of TG Pro to get the diagnostic function as Apple messed up the diagnostics in some versions of the system firmware. In any case let us know what the diagnostic code is
Reference: Mac startup key combinations
da Dan
The correct answer is mine
da Dan
