GPS disfunction after replacing display.
Hi.
After successfully replacing the broken display of my iPhone 3GS my GPS doesn't workt anymore.
Did i do something wrong?
regards,
Max
Questa è una buona domanda?
Hi.
regards,
Max
check that you didn't bump connector 6 off..it's only a tiny round connection for wifi/gps and difficult to notice it not connected.
connector 6 is still connected.
If the WiFi works perfect then #6 is connected OK. GPS will not work correctly if you have installed iPad baseband 6.15.00, tap Settings App>General>About>near bottom, modem firmware #.
Wifi works ok. My moden firmware is 05.15.05.
try resetting network settings.... settings/general/reset/network settings.
reset network settings doesn't work.
Hello
I have the exact problem.... i am trying 5 days to solve i tryied everything....
does anybody knows something? or i have to change the entire motherboard??????
Hello I have the same probleme.Please help
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 678
