Salta al contenuto principale
Un piccolo aggiornamento del MacBook Air di fine 2019, con lo stesso numero di modello (A1932) e numero EMC (3184). Questo modello ha uno schermo True Tone e una batteria leggermente revisionata.
80 Domande Visualizza tutte
New top case and logic board and keyboard isn't working still
I replaced top case keyboard for someone and the keys aren’t working still so I tried a new logic board and still having an issue where its delaying the letter typed or doesn’t even work at all any idea what else it might be?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi! What all exactly did you replace? Ive had a lot of these MacBook Air Retina models where a bad battery can cause all sorts of weird issues or glitches. These computers do not work right at all if the battery has been damaged or is defective. You said that you replaced the topcase, did it come with a battery as well? Also the trackpad and or trackpad cable or the trackpad connector board can cause similar issues with the keyboard or functionality of the MacBook. The audio board on these can also cause problems, try testing it with the audio board flex disconnected from the motherboard.
Punteggio 1
3 Commenti:
Top case came with new battery
Track pad fully functional
Im leaning on most likely the top case/keyboard battery I got is defective
da
I would test it with just screen, charger port and battery plugged in. If it glitches then it's probably bad or incompatible battery. Also I have noticed that these retina MacBook airs do not like it when you use parts from other MacBook Air models. Even though the parts look identical they can cause weird issues if you use parts from a different year MacBook and it can be a huge headache. This could be why your'e having all these weird problems.
da
Aggiungi la tua risposta
iCare Electronic Repair sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 34
