Salta al contenuto principale
CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
294 Domande Visualizza tutte
Is it possable to update a iPhone 4 to ios 7.1.2
i have an iphone 4 i want to update
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Yes, Apple still signs this OS and so you should be able to update. This is the most recent iOS that the iPhone 4 will support, and is the last update to iOS 7. I believe iOS 7 supported Over the Air updates, but if you have difficulty doing the update over WiFi, you can always try iTunes. If you’re on a Mac, you will likely still need to use iTunes to update as Finder doesn’t support updates on many of these older phones.
Punteggio 0
Aggiungi la tua risposta
keith_themuscovyduck sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 17
