Salta al contenuto principale
Fourth generation of the Toyota Pickup.
48 Domande Visualizza tutte
Can I change my 84 Toyota pickup from a mechanical fuel pump to electr
I had to change my fuel tank in my 84 Toyota pickup can I change to a electric fuel pump
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
ann bourliea what engine is it and right now it has a mechanical fuel pump? The tank you replaced is from what year? There should not be a pump in the tank but we need to know more. Yes, you an convert to an electric pump just mounted externally somewhere on the back of the frame and place a filter before the pump. You can even leave the old mechanical pump on the block. We do need more details so as to find out what issues you foresee.
Punteggio 2
Yes just bypass the mechanical pump and drop the electricalone in the tank
Punteggio 0
Aggiungi la tua risposta
ann bourliea sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 17
Tutti i Tempi: 190
