Salta al contenuto principale
Modello metà 2010, A1278 / processore Core Duo 2,4 o 2,66 GHz
790 Domande Visualizza tutte
Need a replacement wifi/bluetooth cable
I recently replaced all the speakers on my laptop as they were broken. While doing this, I accidentally broke the wifi/bluetooth cable. Is there anywhere I can get a replacement cable for my mid 2010 macbook pro? I found one on the ifixit website for the 2011-2012 macbook pros. Is this the same for the 13in mid 2010 macbook pro?
Thanks for the help in advance!
Questa è una buona domanda?
Punteggio 0
3 Commenti
Can you post a few picks so we can see whats damaged Aggiungere immagini ad una domanda
da
Thanks for your reply Dan! I just added a picture of the cable that's damaged.
da
Update: was able to fix it by properly straightening out the pins and insert it into the connector. The internet and Bluetooth work!!
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Just in case, here’s the needed cable 13” MacBook Pro, Airport/Bluetooth/iSight Cable, Apple P/N 661-5558. Here
s the guide you’ll need to follow MacBook Pro 13" Unibody Mid 2010 LCD Replacement We don’t have a direct guide for the data cable but is’t pretty straight forward once you open things up.
Punteggio 1
Aggiungi la tua risposta
ADS sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 61
