Salta al contenuto principale
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
203 Domande Visualizza tutte
Nintendo 2DS XL won't turn on without being connected to charger.
2DS XL wont turn on without the charger. It could turn on before I replaced the screen. Now it wont turn on for some reason. Was hoping if there's some sort of fix.
Questa è una buona domanda?
Punteggio 0
3 Commenti:
Can you use a multimeter to check the voltage of the battery?
da
@andrewsawesome No, but the battery works. Thought it was the battery so I replaced it with a spare one from another 2ds since they were the same and it didn't work. Both batteries worked on the 2ds tho.
da
check connections to the battery on the gameboy side of things. if u have a multimeter that would be the best way.
da
Aggiungi un commento
2 Risposte
Hi,
That typically means that the battery is completely shot. The system basically sees the device with no battery attached. That’s why it will die immediately if you unplug it. I would recommend replacing the battery.
Jason
Punteggio 0
2 Commenti:
Hi, I replaced the battery with a spare one from another 2ds and it didn't work. Both batteries worked on the other 2ds tho.
da
At that point, I would start thinking it’s a motherboard issue.
da
Omg this happened to me years ago but I'm in electrical engineering school now and can actually fix it so imma give it a go
Punteggio 0
1 Commento:
Nice, but I fixed it long time ago. It was the fuse close to the battery. Changed it and it worked again.
da
Aggiungi la tua risposta
Asura Destroyer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 202
