Salta al contenuto principale
The Nokia 5130 XpressMusic is one of Nokia's mobile phones in the series of XpressMusic. It was released in January 2009 and discontinued in 2011.
26 Domande Visualizza tutte
'charger is not supported' message comes
when i am connecting the charger to the phone there is "charger is not supported" message comes..then i had tried with different charger.but the same message comes and my phone is not being charged.plz any one help.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
4 Risposte
Risposta Più Utile
meghna gayen, check on here seems like a common problem. Looks like changing the 47k resistor works for most people. Of course make sure that you have the charger for your phone...;-)
Punteggio 1
Nokia 5130 charging not supported.
Solution is here now
Punteggio 1
1 Commento:
Mehak Mahoo, same solution as above.....;-)
da
Change the battery
Punteggio 0
Change the battery if you repair you battery after some time this problem come again and again so kindly change your battery
Punteggio 0
Aggiungi la tua risposta
meghna gayen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 5,324
