Salta al contenuto principale
Motore per tosaerba Briggs & Stratton 190cc Modello 120000 Quantum 675 Series. Rilasciato a febbraio 2011. Per tosaerba con coppia da 6,75 ft-lb.
Leaking oil out of the front of the motor where it says ohv?
Leaking oil out of the front of the motor where it says ohv. What do I do to repair?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Get your gaskets checked. If it’s leaking from under the OHV part, that means that the cover has a hole, or the gasket has failed.
Clean your engine thoroughly, then run it to see if that is indeed the source of the leak, and get back to me with the answer.
Punteggio 0
1 Commento:
I've exact same issue. B&S 140cc. It's more than leaking from OHV. AND ON 2 mowers!!! New gasket, no change. Valve covers are fine.
da
Aggiungi la tua risposta
redskinreese sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 24
Tutti i Tempi: 1,593
