Salta al contenuto principale
Lanciato il 4 novembre 2017. Modello A1865, A1901. Disponibile con GSM o CDMA / 64 o 256 GB / Colore Silver o Space Grey. Si pronuncia "iPhone 10".
1198 Domande Visualizza tutte
iPhone X motherboard has large current but doesn’t get hot
Hello, I have an iPhone X motherboard which has a very large current when plugged into the DC power supply, however it does not get hot. This is just for the top layer of the motherboard, the top and bottom layer are separated. What could this be caused by? Thank you for your help!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If heat is not visible on the board and producing a large current draw it will be coming from an IC. In my experience it will either be Tigris or PMIC.
Remember no heat on board rules out small components like caps. The x has a large ground plain and that is where the current is going.
Punteggio 1
1 Commento:
Hey, Do you have a Thermal Camera?
da
Aggiungi la tua risposta
Colby Morris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 40
