How to open the 6S Plus
I Cannot open my 6S plus using the heat pry method. Will the iSclack tool work.
Questa è una buona domanda?
If you’re having trouble opening the screen of the device, double check that the pentalobe screws at the bottom have been removed and that they haven’t snapped and left a piece of metal holding the screen to the frame. The tool being used won’t make too much difference if the screen and frame are still screwed together, but the iSclack would certainly be easier to use and even just pop off the plastic parts of the screen that the screws go in. Not good if you’re using the same screen again though.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 42
