Salta al contenuto principale
Dell Inspiron 1420 14.1" laptop, released in June 2008. Identified as the 1420 on the bezel above the keyboard, available in 8 different colors.
some keys don't work on normal pressure
not too long ago some keys started misbehaving, they’ll work when pressed hard but not under normal pressure . Is there a way to fix this without changing the entire keyboard?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
From my experience there isn’t often much that can be done. You can try to pop off the keycaps and clean underneath them but you risk snapping the plastic mechanism and it may not solve the issue. Best bet is to replace the keyboard, for laptops of this age they typically aren’t too expensive and can be found pretty readily on sites like eBay and sometimes Amazon.
Punteggio 1
Aggiungi la tua risposta
Felipe9999 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 206
