Salta al contenuto principale
Processore quad core Intel Core i7 da 2,0. 2,3 o 2,6 GHz (fino a 3,8 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
580 Domande Visualizza tutte
rMBP 15" late 2013 wont boot up, black screen, chime on, backlight on
Hi
I have Retina Macbook Pro 15inch late 2013 with discrete graphics.
When press the power button, macbook won’t boot up, screen is black (with blacklight on and white apple logo turned on) and the chime is on. I can hear the fan and laptop is able to get charged.
I’ve tried SMC, NVRAM (that caused that the chime started to sound), target disk mode, recovery mode, single user recovery mode. Nothing happens.
I’ve opened the macbook and disconnected the battery and connected back again and the same happens. and not luck. still black screen.
Everything happened after I installed Intel Power Gadget software. (I had mojave installed)
The mac started to get freeze after every boot, I was able to remove the software, but for some reason still was freeze in every reboot. I’ve rebooted multiple times until I got the black screen.
Do you think guys that I need to replace the logic board?
I was thinking to clean the fans and put new thermal paste? t
I really don’t want to spend a huge amount of money on a new laptop.
Cheers
Liquid Funk
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
If you suspect a software issue, boot into Safe Mode by holding down the Shift key on start up.
Punteggio 2
3 Commenti:
Hi @mayer thanks for responding. I’ve tried Safe mode, single user mode and recovery mode without any luck.
da
Try this one, disconnect the mag-safe and battery. Press and hold the power on button for ten seconds. Reconnect the battery, then the mag-safe. You should get a spontaneous reboot.
da
Hi @mayer sorry for the late reply. Thanks for suggesting a method to troubleshoot. I've tried and unfortunately it didn't work. I've decided to get in contact with local independent repair shop that specialised in macbook logic board repairs. To have them inspected and check if the issue is the logict board and if they can repair it.
da
Aggiungi la tua risposta
L Q sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 65
