iPad Air 2 backlight spots
Have a issue with iPad Air backlight. It has spotlights and Ive tried a new diode, new filter but its the same. I will attach pictures if possible
Questa è una buona domanda?
Myron, Myron, Myron…
you've been in it for so long, you shouldn't have any problems with the basic methods of mictoelectronics diagnostics. Take a multimeter and check the voltage and resistance values of the backlight power channels. Don't forget about continuity of logical lines. Finally (if not electronics), it may turn out that the LEDs on the screen have turned off (maybe due to previous experience or simply because of a damaged connector). Change a screen assy for test.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 32
