Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
iPhone won't turn on after disconnecting battery and screen a few time
Hi,my iphone 5s won’t turn on after i disconnect the battery and screen a few times but before this it was fine sometimes it can turn on sometimes it stuck on boot loop and turn itself off after that but now it won’t turn on at all even when i change the battery and screen to the old ones that i had lying around.even when i tried to charge it,it still doesnt turn on but the back of my phone feels hot a bit when i left it charging so does that mean the logic board is still ok?can anyone tell me the reason cause i hope its not the logic board thats dead…
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
did you disconnect the battery before the screen? if you didn’t the iPhone probably shorted out and now deosn’t work properly and I don’t even know if you can fix that. if you however didn’t remove the screen before the battery it is probably still an issue with the phone from disconnecting the cables to much or it just didn’t like that you kept Turing it disconnecting the cables so much. honestly I really don’t know what I would do in your case but hopefully this will be helpful
Punteggio 0
Aggiungi la tua risposta
A&Z TV sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 46
