Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2686 Domande Visualizza tutte
Turn off switch control with broken home button
So while trying to turn on voice control i accidentally turned on switch control and messed up a bit in the settings , I can't move even my home screen cause of switch control and my fingerprint won't work , I wanna know if there could be a way to turn it off without using the home button because mine doesn't work , I tried powering it off but I need to slide on the screen and it won't let me , Help
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Hi @nicoley
Please navigate to Settings > General > Accessibility > Switch Control and turn the setting on or off.
Switch Control can also be deactivated from iTunes:
  1. Connect your iPhone, iPad, or iPod touch to any computer with iTunes installed.
  2. In iTunes, select your device.
  3. From the Summary pane, click Configure Accessibility in the Options section at the bottom.
  4. Select the feature that you want to use and click OK.
Punteggio 0
2 Commenti:
can you download iTunes on a non apple pc
da
@nicoley You can run iTunes on any Mac or Windows 10 PC. Simply Google for "iTunes" and Apple's download page should be the first result.
da
If you have no response on the screen and you home button is not working, plug it into the a computer with your Itunes account on it. Then just restore to a backup from before you flipped the settings. That should fix your issue.
Punteggio 0
Aggiungi la tua risposta
Nicole sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,817
