Salta al contenuto principale
{A1989 / EMC3214} - Rilasciato nel luglio 2018, il MacBook Pro da 13" integra processori i5 e i7 quad-core e grafica integrata Intel Iris Plus.
199 Domande Visualizza tutte
doesn't power up nor can it charge
my 2018 13 inch Retina display MacBookPro doesn’t power up and doesn’t charge. I tried SMC reset as well as as PrAM/NVrAM reset but they all failed to power up. is there another fix I can try before I bring it to a fixit shop?
Questa è una buona domanda?
Punteggio 0
3 Commenti:
Does your charger have a LED on it when plugged in? If so what the colour of the LED. If not, possible the IO Logic Board (The smaller separate logic board) has damage or even a main logic board issue. It could also be a bad battery, which would be the better issue to have.
da
@eazy_pc_repairs - Jon - This series uses a USB-C charger which doesn't offer a charging LED. Really need a USB-C power meter to give you the info on your charger and battery.
da
@danj Sorry about that, I did not think :D Voltmeters are relatively inexpensive (£20 or so) though so OP you should be able to get one quick enough and let us know your findings, Amps draw will tell us a lot about whether its dead or trying to turn on or partly booting :)
Let us know if you decide to get one and let us know. I know my amp lighting cable for iPhones is a huge help :)
Good luck Sir
da
Aggiungi un commento
3 Risposte
When I first got my second hand Macbook it came with a charger that didn’t have enough voltage to charge it - the cable was connected to an iPad adapter. It went super dead and couldn’t power up or seemingly charge. Make sure it is the correct charging block? The 61W one I think.
Punteggio 0
Is there a chance that you can open and try to reconnect the battery connector, because i had a same peoblem before the battery is totally drain and it pwont charge, so i tried to reset battery connector then it work.
Punteggio 0
1 Commento:
I have reset the battery about 10 times now nothing when I put the usb type c multimeter on it it says it’s getting 20V but I’m only getting 0.989A to charging. When I first installed the new logic board I got the chime that the charger was connected but when I put it to DFU mode tried to revive the Mac the restore I don’t get that now but it never turned on
da
i think your peocess of dfu is unsuccessful , just try this link.https://support.apple.com/en-ca/guide/ap...
Punteggio 0
1 Commento:
Yeah that’s guide I went by was no help
da
Aggiungi la tua risposta
Tony Bosco sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 142
