Salta al contenuto principale
detected by computer but won't turn on after being unplugged
i found an old shuffle while digging around a drawer and wanted to try it out, it syncs and is detected by itunes (flashing orange light) but won’t even function by itself
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
I had this exact issue with one I was given by a friend a few years back. The internal voltage of the battery has likely dropped to far and it has gone into “sleep” where it will refuse to accept a charge in order to prevent anything bad from happening (battery swelling/exploding). To fix this guy, you will probably need to get a new battery and install it. Not the easiest thing in the world, but it can be done. iFixit has a guide for removing the battery and logic board, from there would need to de-solder the old battery leads and solder in the new one, then re-assemble.
Punteggio 1
1 Commento:
turns out it just needed a good long charge, everything is good now!
da
Aggiungi la tua risposta
Luke Timothy Davis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 137
