"Battery was not detected" after installing iFixIt-supplied one
I carefully removed the old, cleaned the case, and installed the new battery, but now the computer says “The battery was not detected Reference Code: PPT001”. I triple-checked the battery control connection, as well as the power connection to the battery itself, and everything appears correct.
Here is what it looks like:
Everything else on the laptop is working properly.
Is there any other test or diagnostic I can run, or should I return it?
I really hate to imagine removing this battery and replacing it. Before doing that, is there an easy way to test the new battery before I do the installation?
Questa è una buona domanda?
Take a tight picture of the small ribbon cable connections (both sides) so we can make sure its installed properly. Post them in your question (edit mode) Aggiungere immagini ad una domanda
da Dan
@danj Thanks. I just posted a picture of the small ribbon cable connection.
Did you want both sides of the cable, while it's unplugged? Or one of it fully plugged in? If the latter, that's what I supplied. Thanks!
da David Van Maren
@djvanmaren - I suspect you got it half way its in your media manager box not posted here in your question
da Dan
@danj Thanks for bugging me about the images.
I cannot seem to get the little cable to go any further into the connector.
da David Van Maren
