Shuts off when clutch let out
It jarred when untrailering now shuts off when clutch is let out
Questa è una buona domanda?
There are safety switches on the bottom of the seat, at the gear shifter, on the blade engage lever, and on the bottom of the mower at the clutch pedal arm. Most likely the jarring most likely either unseated on of those switches or the wire connector at one of the switches jarred loose.
Tried to download manual to locate these switches but it says no longer available. Need to find clutch switch because I think that's the problem
The should be one switch on the bottom of the seat, one behind the dash panel near the blades control handle and one opposite side as clutch pedal under the mower over the cutting deck.
The clutch switch is under the foot plate on the same side as the pedal!
This is for my old Troy-Bilt that is made by MTD. Some Craftsman models are also made by MTD. I would guess that most are wired similarly. I suspect the brake switch as it has a pole that is in series with the seat switch and it activated when the clutch is fully depressed. The switch appears to be item 30.
Good luck.
Ultime 24 Ore: 6
Ultimi 7 Giorni: 48
Ultimi 30 Giorni: 105
Tutti i Tempi: 2,197
1 Commento
Wiggled and cleaned all connections and fixed it. Thanks for all the advice, knowing where to look helped.
da rick.mabry80
