Salta al contenuto principale
Informazioni sulla riparazione e sullo smontaggio per la versione aggiornata del 2020 del MacBook Air. Lanciato a marzo 2020.
38 Domande Visualizza tutte
LCD Assembly MacBook Air 13 inch 2020
can i use 2019 A1932 LCD Full Assembly for this model? tq
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
It might work, but the fit may not be proper and could be risky!
Let’s review what Apple did between the original 2018 & 2019 models and yours!
  • 2018 - Original retina Air
  • 2019 - TrueTone services added to the FaceTime camera
  • 2020 - Butterfly keyboard swapped out for Magic keyboard (back to the better scissor design]
To make room for the newer keyboard the display and uppercase where both modified in the 2020 system. The hinge will be tight as the lid will be lower, forcing the lid down will likely damage it. Think how a pen in a book will damage the book spine. Here the LCD will crack or become damaged ($$).
Basically, I really recommend you stick with the correct part. If you just want to see if things are working and don’t close the lid then it might be useful for diagnostics, nothing more.
Punteggio 0
Aggiungi la tua risposta
Yopie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 14
