Salta al contenuto principale
What would cause the high temp sensor wire to burn up?
What would cause the high temp sensor wire to burn up? I fix the wire but the unit will not heat up and the table doesn't turn. I check the sensor and show continuity on the sensor and on the Megatron.
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi @titan2021 ,
What is the model number of the microwave oven?
da
It's a LG Model # Lmv 1831 st
da
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @titan2021 ,
Don’t know that model but have you checked that the thermostat(s) are OK, part #5016 & 5116 - interior parts diagram?
Punteggio 1
1 Commento:
I have check sensor 5016 but didn't check 5116. I will check that and let you know. Thank you for the help.
da
Aggiungi la tua risposta
Micheal Roberts sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 15
Tutti i Tempi: 301
