Salta al contenuto principale
Charge is decreasing on charging
Power problem not chraging
Questa è una buona domanda?
Punteggio 1
1 Commento:
Chances are your charger is either dysfunctional or doesnt provide enough power to the tablet, try isolating whats going on. Try a different charger if it works you know the OG one is either broken or insufficient.
da
Aggiungi un commento
1 Risposta
This is probably not an issue with the tablet itself, this is probably the charger you’re using. Try using the charger provided by the manufacturer or use a different cable/adapter.
Punteggio 0
Aggiungi la tua risposta
Suvosree Ray sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 504
