No steam coming out of my steam generator iron
Morphy Richards steam generator iron has stopped steaming
Questa è una buona domanda?
Hi Susan,
Your steam vents might be clogged. You need to descale the iron. You can either buy descaler solutions or make your own. The simplest and most cost effective way is to mix distilled vinegar and distilled water 50/50 in a cup and use it as a solution.
Make sure you unplug the iron beforehand. Also empty the water container in the iron.
Pour the solution in the iron. Look at the bottom of the iron where the vents are and use a toothbrush or a bamboo skewer to clean the holes.
Switch on the iron and set it to max heat, let the solution heat up and dissolve the limescale that possibly have built up in your iron until it starts flowing through. Burts the steam out good number of times until it stops producing little sand-like particles. You can do this over a thick towel.
Then unplug your iron and pour out the remaining descaler/home made solution and wipe off the soleplate once it cooled down.
Thankyou so much will try to do that now
Ultime 24 Ore: 11
Ultimi 7 Giorni: 151
Ultimi 30 Giorni: 624
Tutti i Tempi: 6,152
