Salta al contenuto principale
Fibre e materiali tessili che vengono indossati per stile, sicurezza e protezione dagli elementi.
342 Domande Visualizza tutte
"welded"/glued zipper seams delamintaed
The welded or glued zipper tape to fabric seam has come undone on all three pockets (both hand pockets + chest pocket) of my beloved R2 (see attached pic). Can this be fixed and, if so, how?
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Give this a try! Aleene's Fabric Fusion 4 fl oz, Permanent Fabric Adhesive Use a throw-away glue brush to spread evenly across the surfaces.
Punteggio 1
2 Commenti:
Thanks for the tip! Will this solution hold up over time... esp. in light of the fact the pockets get lots of use and stress/strain. Thanks again
da
@rpmooreii - I've had good success fixing a few things.
The trick is to get the edge so you don't have a loose edge which can be caught.
da
Aggiungi la tua risposta
Roger Moore sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 452
