Salta al contenuto principale
Released in 2013, the Asus X450 is a 14-inch laptop with a 1366x768 pixel display.
4 Domande Visualizza tutte
My laptop can't boot
my laptop is ASUS X450C/X450CC. Before this happens, I can turn on this laptop normally i change my cmos cr23032 battery, bought a new adapter, change to ssd and change the keyboard . After I finish changing the keyboard and tested it. I can turn on and turn the laptop just fine. but after I screw all the motherboard screw. I can’t even boot up my laptop. is it possible that I made some mistake and short my motherboard or something? or did I damaged the power button, because not even any fans are spinning. can someone help me? thank you
Update (02/25/2021)
Okay, thank you. I will try to do it again.
here’s the current state of my laptop
i really don’t know what i did wrong but thank you so much for helping
Update (02/25/2021)
I tried to turn it on but nothing happens. Is it possible that shorted out the motherboard? thank you so much, mike for the help.
Update (02/25/2021)
I think this is what causes all the problems. I’m so sorry that I’m so stupid. I applied hot glue gun to attach the new keyboard and they’re so many glue tips that putting the pressure on the motherboard. maybe that’s what makes the laptop won’t start. I’m so sorry for the inconvenience. I really hope that I can find a way to revive this laptop again. thank you so much for helping, mike.
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi Afiq,
Yes wasn't a good idea. Cause and effect. So you weren't able to power on as you described "After I finish changing the keyboard and tested it. I can turn on and turn the laptop just fine. but after I screw all the motherboard screw. . ."?
Sorry I can't be of more help.
Good luck, Mike
da
@aactech thank you so much mike. I think the laptop is dead.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I don’t see how you could have damaged the power button. All you can do is take it apart again but re-assemble very slowly and carefully watching what you are doing. Take your time, look at and think about everything you are doing. Make sure all ribbon cables are connected correctly and carefully (probable cause of problem) and those that need to be folded away so there is no stress on the mainboard.
Punteggio 2
Aggiungi la tua risposta
afiq zaim sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 18
Tutti i Tempi: 416
